Originally Posted by spendy
The stock belts can be routed through the lower holes in the side of the seat, that will let the belt fit tight against your hips. Just remove the lower bolt that holds the telescoping belt, route belt thru seat hole, and re-attach.
Interesting, do you happen to have photo of what this ends up looking like? Especially interested in the how the buckle goes into the stock receptacle after going through the hole in the center console side of the seat. Do you have to route it through the side hole each time? Thanks!
