I finally started to remove the lines/ hoses. However I can not find out how to disconnect one of the secondary air lines. In this pic you can see four black nylon hoses the two to the right are the fuel lines. The other two are to what I believe to be to the secondary air to charcoal canister lines one of them has a quick disconnect (the one on the outer left) however the one (inner left) hose does not or at least that I can find. Can anyone confirm that these two lines are indeed for the secondary air to charcoal canister lines and does anyone know if there is a quick disconnect fitting on that line and where it is located.
Also I believe I will be removing three inches here. I should have about two and a half inches left of reword moment and a little recline. That said i'm 5,9-10 but I guess have short arms with the steering wheel all the way extended and the seat all the way back I have to slightly lean forward to reach the wheel and my legs are fully extended to reach the pedals. I will also be going with a different seat it will probably sit higher so I should have more then enough room. That said I have a built miata that I use for auto cross and the boxster feels huge in comparison. I may even be able to remove another inch the plan in to get the highest point of the boxsters engine compartment almost flush with the 911s B pillar/ door jam.
