Old 01-10-2015, 09:49 AM   #238
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Boxe1 View Post
Hello i made a big mess on my Boxster S 987 3.4 L
I remove the flange to change the rubber seal of IMS without locking the Crankshaft
and now the shaft is on a side.
What should i do now !
Please check the attached photos
Thank you in advance.
I think that happens to more than a few people.
I don't know if it will help, but read through this thread if you haven't already:
IMS Install help! IMS bearing not centered
Be very cautious how you proceed. As Flaps10 implied, you will probably have to release all the tension from your cam chains, recenter the shaft, then reset your cam timing. Trying to force anything or taking short-cuts will probably damage your engine and lead to more problems.
