I just had a similar problem shifting from 1st to 2nd. It ended up being the motor mount that caused the problem. The rubber goes bad on these things with age. Start with the easy stuff the other guys described first. The syncro is the last thing on the list of possibles with the gear oil change (should do this anyways if it has not been done in the last few years) easily telling you if this is the issue. Good luck.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
