Originally Posted by ralegen
If I plan on replacing my stock shocks, is Blistein HD the way to go?
If you don't have lowering springs, get the Bilstein HD. Alternatively, you could get the M030 shocks and springs for about the same price if you search hard enough.
Also, I know you feel positive that your shocks are causing the clunk, but worn shocks don't clunk. The hardware that they MOUNT to, does. If you replace your shocks, you should also replace the part highlighted with the red arrow in this pic. It is a common source of the clunk. They are around $75 each and can't be removed without a spring compressor, so neglecting to do them now could mean repeating the labor to get to them later.
