Old 01-01-2015, 09:20 AM   #3
JFP in PA
Originally Posted by fishski View Post
I just received my Durametric package in the mail and immediately went out and starting playing with it. I bought it specifically to check my cam dev which from my searches on this forum and others I believe the acceptable values need to be +/- 6. Pretty sure I am in spec but want to make sure I am readying this correctly.
I have an 01 S with 21k. Obviously concerned about the IMS which I know can implode at any time without warning.
The engine is still within spec, but one side is close to the limit, which could indicate chain pad wear. Normally, you would run the car on the road until it is thoroughly warmed up before taking these measurement's as doing it on an only slightly warmed up engine will generate misleading results.
And, yes, straight lines at idle are a good thing.
