Old 12-30-2014, 06:24 PM   #11
particlewave
Originally Posted by Reebuck1 View Post
Your LCD is gone. It can not be replaced unless you have unusual elect. repair skills.
If you want it corrected you will need a new instrument set.
You're replying to a 2 year old post
FWIW, the HSC ribbon is really easy to remove and reattach if the proper tools are used. These are 180°C ribbons.
If you have this problem, you can find a bad cluster with good LCDs and swap them out
I'll do a full write up on the procedure soon.
