Old 12-27-2014, 10:25 AM   #4
thstone
You should be able to remove the extra dowel by backing up the gearbox a little and using vice grips, but you should ensure that the dowel on the opposite side is in place.
VICTORY!
Backed off the trans a bit and used a vice grip to pull out the dowel on the engine side. Then with a bit of wiggling, the trans slid home!
I'll pull the trans back a bit again and insert the dowel on the passenger side.
Then back to re-installing everything else.
Thanks to all!
