Old 12-26-2014, 06:25 PM   #3
steved0x
steved0x's Avatar
It also helps to buy two long bolts (same size as the trans bolts, but longer) at Lowes and cut the heads off of them, then thread them in finger tight on bolt holes around the 9 and 3 O'clock position. These will work well as both guides and supports while fiddling with getting the trans aligned.
If you get them at Lowe's you can get the heads cut off where they sell chain using the link cutter. I got guides for doing my sump cover that way.
