So for reasonable tolerance. If I use a digital inside inspection micrometer on two axis's say 12-6 and 3-9 on every hole in the tappet housing and there is less than .0002" to .0004" variation, the housing should be OK to reuse.
Then if I purchase a new OE Porsche lifter I should be able to install it with out a second thought.
