Old 12-08-2014, 10:35 AM   #4
Carlisabadman986
Carlisabadman986's Avatar
Originally Posted by Steve Tinker View Post
It sounds like your original switch assembly has been changed out for the later type.
The electrical portion of the ignition switch for a 2001 car should be #4A0 905 849 B coloured black - later switches are white and they are not compatible. It sounds like the later complete assembly (electrical switch and metal tumbler) has been fitted to your car.
I've never seen such a loose fitting ignition key, so I'm assuming the complete ignition mechanical + electrical assembly is faulty and needs replacing - a lot more $$ than just the electrical portion....
Hello and thank you for your response.
That is what i thought as well. If that is the case then this would be the second time the ignition is being replaced on a car with only 80K. Seems strange.
Carlisabadman986 is offline   Reply With Quote
