Old 11-10-2014, 11:27 AM   #10
Perfectlap
Perfectlap's Avatar
Originally Posted by jpc763 View Post
So the retro designed by Nine8Six is still the only "plug and play" upgrade for my standard lights?
John
All factory and aftermarket Litronics are "plug and Play". Particlewave was referring to factory-installed self-leveling Litronics. The wiring in those can't really be re-created as a DIY upgrade.
You lose the self-leveling function if you just slide in the Litronics to upgrade the halongen units.
But I'm pretty sure that these aftermarket lights ChuckW has posted don't have self-leveling and instead use the special tool to manually lower or raise the projector height into a fixed position.
I'm not sure how you would correct the position of the projector in a used factory self-leveling unit if went into a new car. I'm going to guess that you can still use the special tool on those since the housing is probably the same?
BORN: March 2000 - FINLAND
