Old 10-30-2014, 07:17 PM   #15
Jake Raby
Engine Surgeon
When I performed the install several years back Jake told me to place the sticker on the inside of the driver's door jamb just above the striker bar.
That one was a long time ago, back when we sold IMS bearing kits to the public, not just installing them.
As far as keeping your old bearing:
Doing this means you have no warranty. The reason the old bearing is to be returned is so it can be inspected and entered into a data base reflecting the IMSR serial # that you were issued. This is so LN can ensure that your old bearing was not failing, because if it was, your retrofit bearing will also likely fail, unless extreme measures are taken.
US Patent 8,992,089 &
US Patent 9,416,697
