Thread: P1601 code
Old 10-24-2014, 05:55 AM   #3
JFP in PA
Im looking at a 04 996 and when I check for codes I got
P1601
Porsche fault code 660 - CAN timeout - instrument cluster
Anything to worry about?
The seller said he checked and it had to do with the battery going flat before he replaced it
Just want to make sure I'm not being fed a line of bull
It may be from a battery issue, but there are other potential sources as well. Normally, we would clear it and see if it returns before becoming concerned on a car in use, but I would be very circumspect about buying a car with the code active. You have to ask yourself why the current owner did not clear it if all it is was a bad battery..........
