It should go to a rubber Tee. One end of the tee goes back to the vacuum canister and switch under the manifold tubes between cylinders 1 and 2. The other end goes to a switch between the manifold tubes at cylinder 4 and 5. This one also branches over to the air damper butterfly on the front cross over tube.
