Originally Posted by mikefocke
P1341
No triggering of the actuator, active position nevertheless.
– Short to ground
– Actuator faulty
Triggering of the actuator, no active position – Open circuit in triggering wire
– Open circuit in B+ supply
– Actuator faulty
No active or passive position is detected
– Actuator faulty
Comes down to wiring or actuator.
So could this be the Cam Position Sensor itself? Not possible, not likely? Would that be throwing a separate/additional code if so, or would that just fall under the "Open circuit in triggering wire" part of the 1341 code?
Thanks a lot for the reply Mike, I've used your site many many times BTW!!
