Has someone installed a short shift kit on this car. The reason I ask is the shift knob is loose which would not be too normal unless it was disassembled. The cable being miss adjusted would be the second clue. I would guess you need to take the console apart and adjust the lateral cable. Pelican has a good write up on how and there is a post on here from about 2 months ago.
