Ok
3 wires coming out of the resistor.
Green/white. Goes from resistor to fan.
Green goes from resistor to connector.
White goes from resistor to connector.
I believe the green wire and the white wire are 12 volt input for the two fan speeds.
The green with the white stripe, is the output to the fan.
Another black wire ( ground) goes from connector to fan.
Measured tresistance between the green/ White, to the other Wires.
Between green/white and green -0.8 ohm.
Between green/white and white - 0.2 ohm.
