Old 09-15-2014, 05:49 AM   #3
jb92563
jb92563's Avatar
Why use a restrictor when you can simply install a "variable restrictor" ie 160F T-Stat that will try to match the temp to optimum all the time.
Not sure I see any benefit to a restrictor as it only allows one fixed flow rate regardless of coolant temp.
Really whats needed is an electronic ECU controlled T-Stat.
