Old 09-11-2014, 01:00 PM   #2
thstone
Boxster S:
front- 28mm new, 26mm limit
rear - 24mm new, 22mm limit
To calculate how much wear you have left;
Step 1. Subtract the existing thickness from the new thickness
Step 2. Divide the number of miles since the rotors were installed by Step 1.
Step 3. Subtract the min thickness from the actual thickness of the rotor.
Step 4. Multiply Step 2 by the remaining thickness of the rotor (until it reaches min thickness).
This will give you an approximation of the number of miles until you reach the min thickness. This assumes that rotor wear is linear and that you continue to drive the same.
Example: LF
The average of the three measurements is 27.39mm
Assume 5,000 miles since rotors were new (USE THE ACTUAL MILES!! This is just my assumption for this example.)
Step 1: 28.00 - 27.39 = 0.61mm rotor wear
Step 2: 5,000 miles/0.61 = 8,197 miles per mm of rotor wear
Step 3: 27.39 - 26.00 = 1.39mm remaining rotor wear
Step 4: 8,197 x 1.39 = 11,394 miles until the rotors reach 26mm min thickness.
