Old 09-08-2014, 07:43 PM   #10
Sanford_yee
The proper method of registering an IMS Bearing Retrofit requires the old bearing to be sent back to LN, where it becomes part of a data base.
ONLY if it has a serialized Flat 6 Innovations decal in the door jamb, as installed here at our facility during the installation.
Jake: This doesn't make sense. The only time you have the vin in a database is if you install the bearing and you send it back to yourself? Did I read these posts correctly?
Sanford_yee is offline   Reply With Quote
