Thanks for the support guys.
Its a great relief to have cleared that major hurdle without spending much $$$.
Now I'm reading about the Door lock issue and have found several tricks and background info on what that could be.
Apparently the Key FOB can loose its programming/sync at several levels and there are several ways to restore it.
Since I kept my original Key, but replaced the donor RFID pill and transmitter part I did not think there should be any issue like this.
It is possible that the button on the FOB may be faulty by one description that I read, and the donor car did crash so...
I'll document what I find here and especially if one of the DIY methods work.
Just an FYI, the Mileage on the car remained the same when I replaced the computer ECU. That info must be stored in the instrument clusters memory.
However all the other info like revs in various ranges, total hours, the VIN paint codes, options and other stuff are from the ECU.
I suppose I could get all that changed at the dealer but since Im not thinking of selling its of no consequence at this point. I'll add all that info to my documentation file though just in case its ever needed.
"It broke because it wants to be Upgraded  "
