Old 09-05-2014, 02:34 PM   #2
epapp
epapp's Avatar
It sort of sounds like the beginning stages of the crank position sensor failing. Can you check your timing at idle and acceleration? Also, your fuel trims would tell you if the oxygen sensors are the culprit
epapp is online now   Reply With Quote
