Old 08-27-2014, 03:24 PM   #1
3_Angels
3_Angels's Avatar
You may check my pedigree by a search on my user name. (I have done the transmission rebuild for second gear successfully) Reinstalling the tailshaft is quite easy if you follow the link I followed and posted. It takes two people; one to hold out the reverse shaft and align the shift fork, and the other to lower the tail piece into place. Use Loctite 574 flange sealant as recommended by Gbox. Good luck on the engine rebuild. (Special care in cam shaft timing!)
3_Angels is offline   Reply With Quote
