Old 08-25-2014, 11:54 AM   #1
thstone
Originally Posted by heymanwatchthis View Post
thstone,Thanks for the feedback, I remember reading what you went through and hoped you would reply. Is this something to fix preemptively, or just let it go?
My main point was to say that the ticking is reason enough to take the car in and have it evaluated.
To answer your question, if the problem is the lifters, my understanding is that they can be replaced preemptively and may not require removal of the engine. Of course, you'd have to take everything (miles on engine, planned use, budget, etc) into account to determine what the best path might be for you.
If someone says its the lifters, be sure to ask the mechanic about replacement of the lifter carrier/cradle also as there have been reported instances where new lifters were installed in a used carrier/cradle and shortly thereafter one of the new lifters failed.
With all of that being said, a 3.6 upgrade sure sounds tempting, doesn't it?
