I've tried banging on it with a dead-blow hammer. No luck. The aluminum braces will go on fine but the triangle shaped cover is not even close. Almost half a bolt diameter off. I've already thought about drilling the big hole idea. Good idea. I don't think the rear suspension mounting point where the studs are sticking out could've moved?? Was there a certain order you put the pan back on in?
