Thread: EVAP CEL Reset?
Old 08-14-2014, 11:03 AM   #2
steved0x
steved0x's Avatar
It should/may go off by itself after a few drive cycles now that the problem is corrected. Back when I used to get 1128/1130 they would come on and then go back off after a few days. Or you can disconnect the negative side of the battery for a few minutes to clear them. But when you re-connect it you will have to enter the radio code, and also redo the window up/down learning for the auto-touch, and possible also the throttle calibration(turn on the key and leave it for a minute or two, and then turn the key back off without touching the accelerator pedal).
