Old 08-14-2014, 08:04 AM   #26
jb92563
jb92563's Avatar
Ordered a working Throttle body and Pedal module from a dismantler.
Hopefully that will fix my "Mistake/Accident" issue.
If not then I'll have to take a look at the ECU to see if it got damaged.
I also bought an ECU, Immobilizer, Ignition/key assembly matched set in case i need to try the ECU replacement, only $265 delivered for all 3 for my exact model year 2001 S.
I also discovered/read about another set of high amp (60A+) fuses hidden away in the car but I doubt these have anything to do with my problem.
I'll try the Throttle body first, then the pedal, ECU is a last resort.
