Old 08-04-2014, 06:54 AM   #2
jb92563
jb92563's Avatar
I got my 2001 S for 14.5k with 55k miles. You can never have too much power in a Boxster and many folks spend thousands on performance mods of all sorts to get a few HP here and there so buying an S for $1k-2K more is worth it, bigger brakes, more HP, thicker cylinders (Room to bore out the diameter and get even more power if you just can get enough) and a bigger smile.
Also if you pick your serial numbered car carefully you can have double row IMS bearings which are also more robust and less prone to IMS issues, 1% failure rate vs 5%+ failure rate for the single row IMS bearings.
