Old 07-30-2014, 07:56 AM   #25
jb92563
jb92563's Avatar
Originally Posted by wawa View Post
I had change the fuel pump without any change. I had been told it usualy is not faulty, but I didnt want to take the chance.
You could try passing a second ground wire and run it for a time to see if it still happen?
Later
Wawa
Being that it is intermittent and seems to be all or nothing, working as normal or running bad, its hard to imagine a fuel pump failing in that way, unless there is an obstruction in the tank.
Perhaps its worth a look at least as I have heard of one fuel pump that broke free from its brackets and was hanging loosely in the tank by its hoses.
You never know if someone has shoved a plastic bag up the fuel noozle so the next person pumping gas gets it in his fuel tank.
