Old 07-20-2014, 10:23 AM   #1
jnicholson30
Update: AOS Connections
Hi All,
Thanks for your suggestions. Picked up some MAF cleaner and will do that shortly. Rechecked the connections. I do see something that looks like it could be an issue? I see a red rubber o-ring on the lower "input" next to the 2 bolts. I don't remember seeing one of these outer rubber o-rings on the old one. Does this look right in the images below?
I am wondering if (A) that could somehow be the o-ring that belongs inside and it didn't slide in; (B) that should not be there and I should reinstall without it; or (C) it is correctly installed.
Any thoughts?
Jeff
jnicholson30 is offline   Reply With Quote
