Old 07-05-2014, 09:38 AM   #7
steved0x
steved0x's Avatar
I have got that exact same baffle, the EBS one, I was able to use the pictures from thstone's thread to help me install it. One thing I would do differently if I ever take that sump pan cover off again, and that is to use the Dreibond. It comes in a tube with a little handle that you turn to force the sealant out. Getting that Loctite 5900 out of the tube and onto the baffle was easily the hardest part of the job for me.
Pelican parts sells it, but oddly I couldn't find it even though I just spent 10 minutes searching their site for it. I bought a tube of it when I thought I was going to have to go back into that area but ended up not needing to.
One big thing that helped me is I took one of the sump cover bolts to lowe's and bought three long bolts with the same thread pattern, and then had then cut the heads off using the chain link cutter, and used them as guides when putting the cover back on.
Good luck!
Steve
