What did you use to check for codes? Have you checked the fuel pressure? With nothing touching the gas pedal and the car off, turn the key to the run position (not cranking) for 90 seconds, turn off for at least 20 seconds, then start the car. This baselines the gas pedal idle position to the DME.
1987 924S. 2002 996TT. PST-2
