Old 06-29-2014, 06:46 AM   #7
davedeck
The mounting was pretty straight forward. I cut just enough grill to hold the light housing and drilled a mounting hole for the bracket. I ran the wiring up to the headlight housing and attached the ground wire to a bolt. The positive is run underneath the seal to the battery area. There is a hole behind the battery that I fished the wire through to the dash floor. I got power from the fuse panel at the heated seats fuse and connected to the switch. That way the lights only come on when the ignition is switched on.
davedeck is offline   Reply With Quote
