			Just to update everyone, I replaced this motor with a used one in 2011 and recently sold the failed motor to Jake with a request for a failure analysis.  Today I received word that it was a stretched timing chain which I assume must have been the chain between the crank and IMS, since valves were bent on both heads.
From page 8 of this thread:
					Originally Posted by Paul  Found some more time today so I removed the cylinder head cover for 4-6.  Looks like 10,000 -12,000 mile oil changes with Mobil 1 at least kept the engine clean:
Another blow down check verified all valves are bent since air flows from both the exhaust ports and the intake manifold:
All chains are intact and working:
I'm guessing the gear on the IMS must have slipped 360 degrees.  This means a complete tear down is needed. |
				__________________1998 Boxster with 7.8 DME, 2005 3.6 liter/325 hp, Variocam Plus, 996 Instrument panel
 2001 Boxster original owner.  I installed used motor at 89k.
 1987 924S.      2002 996TT.        PST-2
 Owned and repaired Porsches since 1974.  Porsche: It's not driving, it's therapy.
