sorry if i wasn't clear enough.
from my post:
"I installed the slave cylinder outside the car just to see how it goes"
when i noticed it is going in hard, i removed it and cleaned the socket.
tried again with a bit of soapy water, and it went in smooth.
i removed the slave cylinder from the trans, installed the trans on the car, installed the slave cylinder with the trans in the car with no issue, connected the fluid line, and bled the system.
good luck.
