The car should drive smooth as silk well past 100mph.
It could be the tire needs re-balancing, in case it lost its weights.
The tire rubber itself if too old or damaged may be developing a problem.
The suspension may be worn and getting loose allowing the shakes to develop at certain speeds.
A rim could be slightly out of round due to hitting a curb but would shake worse proportional to the speed I would think.
Start with the cheapest (rebalance) and work your way through the possibilities.
