Old 06-09-2014, 10:37 AM   #5
steved0x
steved0x's Avatar
Originally Posted by amrenane2010 View Post
Furthermore, when trying to turn on the headlights, I need to turn it on/off a couple of times to actually turn on the light.
Any advice / help out there?
Agreed, headlamp switch, the exact same thing happened to me. Easy fix, see the guide here:
Pelican Technical Article: Boxster Headlamp Switch Replacement - 986 / 987
24 MM socket to remove the big nut, and torx bits to remove the rest.
For immediate relief while waiting for a new switch you can remove the switch, and spray electrical contact cleaner inside it while you rotate it through the positions. It will make it better and can be a short term fix.
Steve
