Old 06-04-2014, 08:38 PM   #8
steved0x
steved0x's Avatar
The redline application guide says this car should use their MT-90, which is a GL-4. I think Mobile Delvac is a GL-5. I use the delvac in the diffs for my tacomas (well I sold one so the one that is left ) and in my FJ cruiser. I use the MT90 in the 5 speed in the Tacoma, and also my son's Miata transmission, which hates GL5.
It could very well be the fluid, and there are not many GL4 out there. I think Brad Penn makes one:
http://www.summitracing.com/search/product-line/brad-penn-multipurpose-classic-gl-4-gear-oil
And redline makes a couple of GL4s, the MT90 is the one I use on my vehicles that call for a GL4:
Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MT-90 75W90 GL-4 Gear Oil
Edit: I may be way off, I was putting in 1988 Porsche 944 Turbo into the redline application guide for the above. I just saw in your sig that yours in a 1989, so I put that into the redline application guide and this is what it recommended for the transaxle: 75W90 GL5
http://www.redlineoil.com/product.aspx?product=58304
Sounds like that is about the same as the Mobile Delvac 75W90. Good luck, hopefully a fluid change will help.
Steve
