Old 05-26-2014, 09:18 PM   #1
Ian c
Litronic problems
I just got called outside to look at the car , 2003 2.7 tip .
Apparently front lights not working .
When I turned them on they just flickered a few times then went off .
After about 3-4 goes they came on and stayed on .
One more try , and they were deemed ok enough for her to make a quick 1mile return trip .
No problems reported on the trip , so I've just been out to do a quick check ...
Lights turned on , key turned to right but car not started . Litronics came on , dipped down , made a noise as if they didn't stop , then came back up to normal position .
I thought they were supposed to go down , then up , then return to normal position ?
I tried it a couple of times and both times they came on no problem , but did the same sequence .
It is parked on an up-hill driveway if that makes any difference ?
One more thing , with the ignition off and lights on , it only had rear lights and side markers lit .
Fog lights , indicators , high-beams all working ok .
Any pointers appreciated before I waste all my day off tommorow on it
Ian c is offline   Reply With Quote
