Old 05-24-2014, 08:38 PM   #67
jb92563
jb92563's Avatar
Originally Posted by Slate 01 View Post
Is the reducer pipe that attaches to the test pipe supposed to just "butt up" against the u-pipe with the original double wide clamp just holding the to pipes together? I'm having a hell of a time getting that connection to work. It seems I will have to cut off an inch or so on both sides to make it work. Something is going on. Help please!
Yes the U bend pipe connects to the reducer by butting up and using the original u tube wide clamp.
Be sure to drive the upstream end of the cat delete pipe reducer all the way as it will likely need to be hammered into place.
you should not have to cut it
