Your going to have a hard time with 11" wheels on the rear they will hit inside un-spaced. When you space them out probably need 20MM they will rub under the fender unless you roll the bead of the fender all but flat. The front 8" wheel you'll need about 15MM spacer to not rub the inside. This is how I run my front wheels with that size tire. Really suggest you ditch the 11" wheel for 10" wheels and 7 to 10MM spacers.
9 1/2" wheels fit nice on the rear with the 275 tire
