The distance from the center of the rim to the inside bolt surface. The bigger the offset the farther the tire sticks out. You can fix too little offset by adding spacers you can't fix to much offset. The second possibility is tire size.
Here is a link
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Reason: Added a link
