Old 05-14-2014, 08:38 AM   #1
jb92563
jb92563's Avatar
Got a new Fuel filter, Gas cap, Oil cap rubber seal and spark plugs to install.
I still feel its a vacuum leak so I'll probably recheck the new AOS install for leaks.
I have this feeling that when I removed the part of the AOS that sticks into the engine block the rubber seal from the old one did not come out on the spigot so when I installed the new one perhaps it did not seal properly.
I will pull the new one and get the inspection camera in there so I can see if that is the issue, as I'm not sure what the old one had on the spigot for a seal, but its reasonable to assume something like the new one has, which was missing when I pulled the old one.
