Old 05-12-2014, 11:29 AM   #1
thstone
Originally Posted by truegearhead View Post
-what happens if you don't get a ROW reflash?
The ECU will illuminate the CEL after failing the SAI test at cold startup.
-how much weight does it save?
The pump alone is about 4 lbs but removal of the entire system (tubes, valves, reservoir, etc) can net about 10 lbs. Like calories, they all add up!
-any reason besides emissions not to do it?
None that I can think of.
