If you remove the plastic over the battery, there's the AC connections as well, located to the left of the battery. Take a screwdriver or something similar, and press down on one of the connection holes (only for a part of a second). If it's preassure in the system, it's not a leak. There might be a broken AC compressor tho, if it's pressure in the system that is.
