Old 05-07-2014, 10:47 AM   #3
megapat
Originally Posted by tonycarreon View Post
are you sure your coolant cap is on correctly? it's very easy to thread it wrong. did you turn on the heater while burping / bleeding? also, the tip has a slightly different "bleed" procedure than a manual by pulling the fuse.
Shd i keep the coolant cap open and click the bleed valve to the vertical position when i turn on the heater? Then leave the car overnite with coolant cap and bleed valve opened?
I reckon the tip has a diff procedure when pulling the fuse... when i unplug the fuse, everythg in the dashboard didnt work... Is it normal or its the wrong fuse?
sorry for asking too many questions... Coz theres just too many question marks in my head nw! Thanx
megapat is offline   Reply With Quote
