Old 05-04-2014, 08:31 AM   #13
JFP in PA
Jeff,
Ok, I spent all morning locating the flange seal, the cam seal plugs and the tool to lock the cams (kindly loaned by BYProdriver)
However, I DO NOT have the center bolt seal, is this seal a special one or can I get away with reusing the old seal along with some Locktite...? (I never heard of the 'green wicking' Locktite)
Another question is for the center bolt, do you simply bolt it in all the way and then use the nut to lock it in place..? Thank you!
Regards,
Gilles
The factory center bolt has a recess machined into it that carries an O-ring oil seal, which is a common leak point.
Green wicking Loctite is a product designed to prevent oil from walking up threaded shafts and leaking, it is not a thread locker, but a thread seal:
Loctite Green Threadlockers|Thread Wicking of Pre-Assembled Fasteners - Henkel North America
The center bolt is part of the IMS bearing assembly, and in this photo you can also see the O-ring seal:
