Thread: OBDII Oil Temp?
Old 04-29-2014, 12:01 PM   #2
seningen
seningen's Avatar
Originally Posted by paulv View Post
I've assumed that your do this for your '00 Boxster ( which is DME 7.2). The oil temperature is checked by the DME because codes P0197 and P0198 are thrown for below/above limits (oil temp is used for cam adjustments). You may be able to see the actual value from your device -- I can check it with my Durametric on my '07.
Regards,
paul...
Yes -- my 00 S Boxster. I'm coming up to speed on OBD-II
I believe the codes are not in the first 32 -- so are extended -- therefore
I need to know the PID and then the characteristics.
I've also found a thread where they think you can display it on the HVAC controls,
but in the long run I'd like to maybe display a good bit of info on a IPAD -- but I'll start
with my phone.
thanks,
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
