Old 04-26-2014, 09:42 AM   #1
jsceash
jsceash's Avatar
You need to replace the clutch, and pressure plate at the very least. There is a plastic pivot on the throw out arm that wears overtime the throw out bearing face wears over time, the fingers on the pressure plate wear over time, and in some instances the fingers on the pressure plate bend. All these items add up to not enough travel. A bad clutch and pressure plate do not always mean the clutch slips.
